gbell
(Greg Bell, Sr CMI)
January 4, 2012, 12:19pm
The state is getting ready to publish the SOP. I have attached a draft copy of the rules. Please read and discuss any concerns you have here,
The SOP should be in effect within 90 days if it is not challenged.
Just an FYI, there are now over 7000 licensed home inspectors in the state.
gbell
(Greg Bell, Sr CMI)
January 4, 2012, 12:42pm
2
I noticed that it is a $1000 fine if you don’t give the client a copy of your exclusions (inspection agreement) before the inspection.
gbell
(Greg Bell, Sr CMI)
January 4, 2012, 12:52pm
4
[FONT=Times New Roman][size=2][FONT=Arial][size=3]61-30.813 General Limitations And Exclusions
I like 4(d) under this rule. Should take care of anyone offering a guarantee or warranty.
[/size][/FONT][/size][/FONT]
gbell
(Greg Bell, Sr CMI)
January 4, 2012, 12:53pm
5
[FONT=Times New Roman][size=2][FONT=Arial][size=3]61-30.812 Site Conditions that affect the Structure
I think that sea walls should be added to number 2.
mnieblas
(Manny NIEBLAS)
January 4, 2012, 12:58pm
6
Thanks Greg, I took a quick look at pages 21 and beyond prety standard stuff. Thanks
evandeven
(Eric Van De Ven, CMI)
January 4, 2012, 1:00pm
7
Wow!
15 pages for the SoP!
Notice that appliances are now part of the home inspection.
mnieblas
(Manny NIEBLAS)
January 4, 2012, 2:04pm
8
I already inspect the appliances.
evandeven
January 4, 2012, 2:10pm
9
So do I and many others. Now, everyone will.
hcarvajal
(Humberto Carvajal, HI884)
January 4, 2012, 2:32pm
11
How does this part coincide with work we perform on a 4-point?..
(3) Inspectors are not required to determine:
(b) The remaining life of any system or component.
or does this not apply when performing 4-point inspections?
Thanks,
Bert
mmeeker
(Michael Meeker, CMI)
12
Isn’t this the best?
Aren’t you all so happy we are now being told how and what to do?
Anyone who pushed for licensing is a fool.
Thanks again butt-wipes.
evandeven
January 4, 2012, 2:33pm
13
hcarvajal:
Thanks,
Bert
Not required doesn’t mean you can’t do it.
evandeven
January 4, 2012, 2:34pm
14
Mike, this is no different than it was. It is how everyone should have been doing it in the first place.
ldapkus1
(ldapkus1)
15
gbell:
Wow. Any idea how many are conspectors ?
hcarvajal
January 4, 2012, 2:36pm
16
I see your point Eric but it does seem a little bit contradictory no? Not “required” yet is “required” when performing a 4-point.
hcarvajal
January 4, 2012, 2:38pm
17
there was also a section I read, I need to go back and pull it, where it said basically we are not required to insert anything (voltage tester maybe) into an electrical device. How are we to determine reverse polarity etc… then? Doesn’t seem to make sense to me.
evandeven
January 4, 2012, 2:41pm
18
hcarvajal:
Not required again.
However, to wander further out into the field and say you ended up in court for a receptacle not being grounded and someone got shocked and you didn’t test it because the SoP said it “wasn’t required”, there is a “Standard of Care” which is what would anyone else do.
At which point, you would lose a lawsuit unless you could prove that no other inspectors were testing receptacles using tools designed to test receptacles.
hcarvajal
January 4, 2012, 2:47pm
19
I totally agree with you and personally will continue to do what I deem in my clients best interest. But, the question does arise as to what can come of this should you just check a “representative” quantity of receptacles as the SOP states and the one you didn’t check turns out to be the one that “shocks” the owner. Then, what does your insurance carrier make of that? Deny your claim due to you performing something not in your SOP? Just curious that’s all.
Bert
bwiley
(Blaine Wiley)
20
Looks pretty standard after a quick read through.
Interesting that under HVAC we have to report the BTUH or KW for heat, but nothing for cooling.
