Who are you going to ask? :mrgreen: I email the client the required pictures with their report.
Do you also scan and e-mail the report. Thanks. Bill
No I fill out the PDF form on the computer with my notes on it and email it all at the same time. Starting today I will likely ad another page to the form and put the pictures right there as part of the same PDF.
I use a 4 page picture template that has the client name and address at the top of each page.
I have 2 to 4 pictures for each of the required sections spread out through the template.
I add details above the photos in each section, ie: Clips, Straps, Hip, Unknown, etc…
I then save the picture document as a PDF when completed. I often use the PDF version of the form that John Shishilla created and provided to any who asked. Thanks John.
I send the PDF picture document attached to an email with the report.
I have a hard copy of the report. An electronic copy of the report and the photos. I have a copy of both saved in my email account.
Good Luck,
I’m in the dark ages compared to you and Mike. If John wouldn’t mind maybe I could get That version also. Thanks again for your responses. Bill
Your welcome.
But why go through all that trouble. Use the paper clip on Adobe and done.
http://honorconstruction.com/files/Sample1802.pdf
Nice,
I see your sample, but the size of my attached pics were to large. The templet I use allowed me to save, attach, and send the pics with little effort. But it is time consuming.
Time is money. Take smaller pictures. I can finish and email the report while they right the check. When I leave I am done.
John. Would you mind sending me the PDF version of the form you use? Bill
Change your profile to tell me where you are from, then send me an email.
I am new to the board. I’m a building contractor in Cape Coral,Fl. I’m in the process of taking the courses here and trying to expand into home inspections as remodeling here is extremely competative. I am also just trying to get a handle on these wind mits. I have found this message board to be a great educational tool. I appreciate the help Ive gotten from you, Mike, and Jay. My company is Prestige Property Enterprise.CBC1257312
"5. Roof Geometry: What is the roof shape(s)? (Poches and carports that are attached only to the facia and wall of the host structure and not structurally attached to the main roof system are not considered in the roof determination) "
I believe that when it says shape(s) that you can mark both A & C (Hip & Flat) otherwise why would they say (s)?
Wouldnt it sat," what are the roof shapes? Not what is the roof shape(s). And the hip description rules out any other shape greater than 10%
It cannot be both.
To be hip, No roof shape greater than 10% of total perimeter.
It must be rated as a flat roof if the flat deck is over 10%(or 100 sq ft), structurally attached, and NOT a carport or Patio.
There appears to be a great deal of difficulty with this section of the report.
I have recieved 4 calls in the past two weeks for reinspections. In each case the client felt their previous inspector got the roof geometry wrong.
The roof had been marked as Flat in section 5 of the roof geometry.
In three of the 4 cases the client was correct. Three of the four roofs were incorrectly labled as Flat.
The inspectors could not accurately determine the difference between wall/facia attachment and structurally attached to the roof. In one case, the inspector applied the 10%** PERIMETER** formula used to determine Hip, to the flat deck. Rather than the 100 square feet/10% AREA formula which applies to flat decks.
I totally agree that the wording implies that more than one choice can be considered. I still say they prefer to keep it vague in order to force a default type decision to the lesser discount.
Does Flat get them a discount?
I doubt their is a discount for flat. But, I don’t know.
One of these client’s says their agent quoted the same price either way. Then again, the agent could only have been trying to passify the client, who was pissed that the roof was being rated as flat.
I did not think Flat did them any good anyway. If that is the case the form should be like it used to be. either true hip or not.
I believe that Flat represents two ‘loss’ issues for the insurance companies:
Unlike say a tile roof, they are probably not going to be able to ‘patch up’ or repair a flat rolled roof.
Unlike a hip or gable, where the wind usually only removes the shingle/roofing on the windward side of the roof. The undamaged sections of the house can still be protected from water damage. If the flat deck fails the whole structure will probably be water damaged.
