Flue Clearance!?
I know on a standard roof-
3’ above roof
2’ above any part of building within 10’
This beauty is right next to wood rail (<2’) and not above roof of apartment wall which is also not 10’ away.
My questions are:
  1. what is actual required clearance to combustible outside? (such as railing)
  2. does anyone have knowledge or pic of how this should be done /extended above roofline of apartment?
    Appreciate any feedback!
A Type B Gas Vent typically needs 1” to combustibles:
How it is to be done/corrected is not as important for an inspector to report on as the fact that it needs to be corrected….if not 2’ above any part of building within 10’.
Thanks Larry-
Agree- i will just write it up…
But i do like to educate myself- typically i see extended flues tied back higher up the roof. Just thinking how this may be secured.
Its a rental- and i personally don’t like the flue being within reach of someone on the porch.
Roof is shot- so if they do a re-roof- relocation would be best.
Great illustration… where did you find it/bottom one.
thank you!
I’ve had it for a number of years and don’t remember where I got it.
Right click on the image and hit “save image as” and you will have it for future use.
