Clearance question.
Originally Posted By: Heath Brier Johns
What is the recommended clearance on the roof for furnace flues. I have a flue terminating below a dormer and about 2 feet to one side of the dormer window. If this window were opened and the furnace was running carbon monoxide would empty into that room. I need the specific numbers on the clearance, thanks.
Heath
Originally Posted By: jbushart
2’ above anything within 10’
Home Inspection Services of Missouri
www.missourihomeinspection.com
"We're NACHI. Get over it."
www.monachi.org
Originally Posted By: away
Heath,
From my Code Check there are 3 references that may apply.
1. Minimum 4' below or to the side and 1' above window or door - IRC 2427.8
2. Minimum 1' above any building opening - ditto
3. Minimum 2' above any vertical surface less than 8' away - I can't find the specific IRC reference for this as Code Check only shows this one in a drawing
Hope that helps.
Andrew Way
Keystone Residential Inspection Services PLLC
817.441.9598
www.keystoneinspections.com
Here’s the picture:
[ Image: http://www.nachi.org/bbsystem/usrimages/T/Trawick_photos_002.jpg ]
Originally Posted By: James D Mosier
Jim Mosier
Heath,
The picture clears things up.
I would say that any or all of the references I cited are applicable in this situation.
Andrew Way
817.441.9598
Thanks Andrew!
Heath
Originally Posted By: lewens
why didn’t they just punch it up through the soffit above in the first place?
Just my usual 12.5 cents
From The Great White North Eh?
NACHI-CAN
www.aciss-brant.com
www.certifiedadulttrainingservices.com/
