mashburn
(Michael J. Ashburn)
September 16, 2007, 7:59pm
I ran into this today. What type of covering is it? Is it asbestos?
Thank you.
bhartley
(Buck Hartley, CMI)
September 16, 2007, 9:12pm
2
Looks like it, have it tested to be sure.
jpope
(Jeffrey Pope, CMI, CHI, CPI, ICC)
September 16, 2007, 10:04pm
3
It’s not a covering, it’s the actual vent. It is called Transite and it does contain asbestos, although that’s not an issue.
These vents will crack over time. Even minor cracks can allow heat and/or exhaust to escape. For this reason, you should always recommend replacement of these Transite vents with modern steel B-vents.
There’s no need to recommend “further evaluation” or “testing” of any sort - just replacement.
gbeaumont
(Gerry Beaumont)
September 17, 2007, 12:41am
4
jpope:
Agreed, it’s a cementatious product, as long as its in reasonable shape no big danger but as Jeff recommends it should be removed.
Regards
Gerry
lcannizzaro
(Louis Cannizzaro, Lic#16000002260 WDI-T2876051)
September 17, 2007, 4:43pm
5
I’ve heard about products that may encapsulate this type of chimney in attic space if it truly is asbestos containing material.
jpope
September 17, 2007, 5:03pm
6
Again. The asbestos is not the issue. The issue is cracking of the vent. The vent pipe should be replaced, not modified.
bkelly2
(Brian Kelly, AZ Cert. # 60234)
September 17, 2007, 5:47pm
7
Replace the transite vent pipe as Jeff reccomended.
mthomas2
(Michael D. Thomas)
September 17, 2007, 5:58pm
8
Jeff, Do you have a cite for the prevalence of cracks in Transite vent pipes? Thanks
mthomas2
(Michael D. Thomas)
September 17, 2007, 6:00pm
9
Jeff,
Thanks
bkelly2
September 17, 2007, 6:36pm
10
Just the age of the vent pipe and that it is single wall is enough to have it replaced.
In cold climates with these vents from the 1950’s era, the real hazard is not so much asbestos fibers as the dangerous obstruction of the vent/flue by the deterioration of the interior of the pipe. The transite flue vent becomes swollen and deteriorated due to condensation of the water vapor in the combustion gases being vented. The acidic flue-gas-condensate combined with the effects of frost in cold climates causes a delamination and swelling and blockage of the transite pipe chimney-flue. A blocked or constricted flue vent pipe can cause production of dangerous or even fatal carbon monoxide gas in the building
http://www.inspect-ny.com/sickhouse/asbestoslook7.htm
mashburn
September 17, 2007, 7:35pm
11
Thank you Jeff, and All for your input. I recommended that it be replaced.
