Metal ducting leads up to …what looks like an older asbestos vent piping.
Should this be called out…( that the asbestos vent pipe should removed ) and replaced with current duct materials?
It’s probably Transite and looks in good condition. I would mention it’s presence only, but would definately report on the improper mounting/brackets attempting to hold it in place. Is that twine???
“The vent includes a Transite pipe, which is comprised of a solid, cement-like material that is known to contain asbestos fibers. Admittedly, these fibers could not easily escape from within the material, but the majority of heat vents, and certainly those that pass through attics, are required to be double-walled, or Type-B. And, as an imperceptible crack in a single-walled vent pipe could result in a fire, we recommend that the Transite pipe be replaced with a modern double-walled type.”
Nice comment Joe, but I don’t think I agree completely with it. I don’t have time to look it up now, but I believe your requirement applies to metal vent material only. Even so, I would consider adding your comment to my report, depending upon more information of it’s condition, as a suggestion vs a recommendation, for safety of course.
Modern standards identify B-vents as “double-walled steel vents,” but the Transite piping used in these applications were (at that time) classified as “Listed B-vents.”
The biggest concern (for me) is the potential for cracks that cannot be seen, but will allow heat to escape. For this reason, I always recommend replacement as a “recommended safety upgrade.”
That’s true, and based on the damage caused in that Virgina tremor last week, it seems the rest of the country is a “third-world country” with regard to seismic requirements
I couldn’t believe the extent of the damage caused by that little shaker.
Many people are surprised that there are actually significant fault lines running throughout the US, including one that runs right below NYC not too far from me. But the ones in CA are much more active and severe. You would probably never know it unless you looked at a USGS/FEMA seismic risk map.
I felt it on Long Island, NY … it shook my house a bit … :shock:
Other areas much less frequently … like every 50-100 years. Just goes to show ya that it’s only a matter of time before a quake hits home. I was just surprised that a quake almost 400 miles away shook my house.
