Originally Posted By: dduffy This post was automatically imported from our archived forum.
Hard to tell from the picture, is there interior wall cracks? Has the stucco been repaired? Where is that drain leading to?.. Could the drain be leaking if it’s not installed and terminated correctly, expansive soil?,… doing a little lifting. Maybe?
Just a guess without seeing it, I will bet the moisture from the drain is a factor regarding the deterioration of the foundation, if this is the only area cracking and deteriorating.
I would video scan the drain, and see where it goes to, if anywhere. The picture is bleak, but expansive soil could be causing the crack.
