#1 Per R403.1.6 7" but loggically if one buys the standard 12" x 1/2" anchor bolt and expect to bolt a 1-1/2" plate it would get embedded 9-3/4".
If pressure treated lumber is used, then galvanized anchor bolts should be utilized, ZMAX equiv…
#2 6’
#3 As many as required to meet # 2 above. Min. could be 12 if the building size would be rectangular with a perimeter of 32’.
ok…my answer is (2)…and one has to be within 12" of the end of the single sill plate…but I just looked…I said Anchor Nolt…what the heck is a nolt…hmmm…
See what happens when an Electrian tries to be a Carpenter, a bolt turns in to a volt, and then a nolt.
Does that mean a no-volt. ?? ha. ha.
Answers really depends on if you are in a high wind/seismic area or not. Additional requirements apply in those areas. And many would be surprised at areas deemed to be high wind/seismic risk areas … like Alaska and parts of the mid-west for high seismic risk … :shock:
[Couldn’t resist, even though I know you were looking for the answers for standard construction not in a high wind/seismic risk area … ]
I agree 100%…while this question was as you said…for the standard construction…you are totally correct…it all depends on the area. I know my house is NOT technically in that area…however…when I built it I took extra steps above and beyond the minimum code standards…because I like on the top of a hill…and the WIND is amazing…40-60 MPH nearly 3-5 times a week…while CALM everywhere else.
