Checking out a new construction crawlspace of a townhome and wondering if I’m mistakenly worried about the lack of visible attachment of the sill plate to the concrete foundation wall when viewing from the top of the plate.
I would expect to see bolts going into the concrete through the sill plate at least every 6 feet but I couldn’t see any at all throughout the span of the sill.
Is there something else with this construction that makes up for it?
The anchor bolts are most likely under that first sole plate. Some drill a hole in the top plate to hide the anchor bolts of the first plate.
Looks like they then used the H-2.5 clips to nail them together.
I don’t know why they used two plates when one anchored properly is sufficient.
My first thought was to guess that they are under the second plate but obviously I can’t verify that. Yes, I also think it’s strange there are two plates…
Would you call it out and say that you were unable to verify proper attachment? If so, what level of defect would you rate that?
Unable to verify sill plate anchorage to the foundation at the box sill areas. Recommend a qualified building contractor to verify.
Can’t call it a defect under assumptions.
There is a way to verify, but that is beyond the standard of an HI.
Agreed. This is one of those tough ones to me from a practical standpoint because you don’t want to raise alarm unnecessarily but i don’t know how easy or costly it would be to have verified by a specialist…
I get it from a liability standpoint but it’s still not an easy thing to categorize, IMHO.
I do a lot of new construction inspections and find these mud sill anchors almost everywhere. You will never see them from the interior if it only attaches to the sill plate.
It’s very difficult to see unless you’re doing a pre-drywall inspection and the siding isn’t on the house yet. Otherwise you can stick your camera phone under the siding and inspect for these anchors.
Agreed, I have done this for many reasons, siding elevations, getting an adequate pitch on sewer lines, or getting an extra 1 1/2 of headroom in the basement if you want to hang a suspended ceiling, etc.
