FPE Fuse Panel
I came across a Federal Pacific Panel in a house built in 1962. The panel was 150 Amps with two main fuse blocks and several fuses. Are FPE fuse panels a concern as well as FPE breaker panels? If so, what should we look for other than the obvious?
FPE fuses are no more problematic than any other brand. Stab-lok brand load centers are the only FPE product that has a “higher than normal” failure rate.
Thanks, That’s what I thought.
