Here is a free graphic showing three installation methods typically used for freeze proof faucets, however in cold climates terminating the connection inside an exterior wall will freeze.
Might be more useful if it showed the valve cut-away to give some perspective to the valve not being on the exterior. Around here they go right through the poured foundation (4-6"). A side view orientation will show how the faucet handle is oriented to the spigot.
You may consider changing the reference from a “faucet” to the industry-standard “hose bibb”.
I think this is a much better illustration.
Hose bibb or hose bib?
