Originally Posted By: lgoodman This post was automatically imported from our archived forum.
So if masons don’t install that veneer wall, who does?
Webster's New WorldDictionary, 2nd College Edition-"Masonry 1. the trade or art of a mason 2. something built by a mason or masons; brickwork or stonework.
Earlier today someone said"careful you may be taken literally". I want to be taken literally and in the exchange of information we should all strive to take each other literally unless directed " Now, don't take me literally".
Dave,
I agree that there is a difference in the way these walls are described in a report. Your posting will benefit those who may not know the difference.
Thank you for providing it.
I was trying to point out that the Question of the Day had two correct answers and "made of bricks" was as valid an answer as "has a header course"
One other point. A mason may build a header course into a veneer wall for aesthetic purposes and to make it look like historic homes in the neighborhood. A headercourse does not guarantee that the wall is not masonry/veneer.
Originally Posted By: bkelly2 This post was automatically imported from our archived forum.
Leigh I am with you. If the wall is made with bricks it is a masonary wall. If has a veneer then it is not a wall made with bricks. Lots of slump block houses here, some sided some not. The window wells are deeper on a block house than a stick house.
– “I used to be disgusted, Now I try to Be amused”-Elvis Costello
Originally Posted By: dvalley This post was automatically imported from our archived forum.
When we say brick veneer, we don't mean those little thin slices that you glue on your kitchen wall. We mean an honest to goodness brick. However, the wall is only one wythe thick. Behind the brick veneer is a wood frame wall which is actually holding up the house. The brick veneer is, in effect, siding!
A veneer brick wall is absolutely made with bricks. A veneer brick wall has one layer of bricks verses a solid brick wall having two or three layers deep. In its most common form, a solid masonry wall consists of an outer layer of brick and an inner layer of brick.
You have to understand the difference between brick veneer and solid masonry. The biggest difference is that with solid masonry, the brick is holding up the house. With brick veneer, the house is holding up the brick!
dvalley wrote:
Brian,
You said...
OK?
Exactly the wood frame wall with brick veneer.
-- "I used to be disgusted, Now I try to Be amused"-Elvis Costello
