Could there still be a fuel tank buried with vent pipe? Seller said gauges/pipes were in home when he bought it but pipes removed when he built shelving. Did not see fill pipe anywhere.
Yes, certainly there could still be a buried tank there…
And, you would do well to refer that possibility out for verification and proper mitigation/removal.
Thanks, anyone have a good narrative for verification and proper mitigation/removal of old fuel tank.
Abandonment requires fill and vent lines to be removed. If done properly with a certificate issued. Wouldnt take anyones word unless you see the certificate
And, if it has leaked into the surrounding soils, you have a new ballgame…:ack:
If that’s the gas meter next to your pipe did you say something about it?
Got it, Clearance should be at least 6’ below decking.
Close. Minimum clearance from grade below meter to deck bottom is 6’ and not under stairs or between doors and stairs.
