Originally Posted By: kmcmahon This post was automatically imported from our archived forum.
Most furnaces have a shutoff switch for servicing, however today I had one that was just plugged into an outlet. Is this ok? Can’t find anything on it. I’ve never seen one just plugged in before, but I suppose you can just unplug the unit for servicing.
Originally Posted By: dvalley This post was automatically imported from our archived forum.
Kevin,
I don't do codes. But if this were my inspection, my report would state....Recommend electrician to permanently install (hardwire) power cord at furnace electrical supply.
Originally Posted By: jsavino This post was automatically imported from our archived forum.
The furnace requires a dedicated circuit. A switch must be hard wired at the top of the stairs, (if the furnace is in the basement) or outside the utility room. But a switch is not required at the furnace, but only installed for the convenience of the service tech.
Originally Posted By: cmccann This post was automatically imported from our archived forum.
John, Not sure what the codes are in NY, but I have never seen a furnace cut off switch at the top of the stairs to a basement. 99% of the homes I inspect have basements, and 100% of the time the furnace has a dedicated switch at the furnace. Do you have some sort of Reference I can look at?
Actually, the switch must be located somewhere along the route out of the space the furnace is in.
Originally Posted By: aslimack This post was automatically imported from our archived forum.
I believe John refers to an oil fired system when he mentions the top of the stairs for the safety switch. For gas fired, i think the best case is within reach of the unit.
Adam, you are correct. It’s oil fired that require a shutoff at the top of the stairs. In electric furnaces or boilers the breaker can be used as the shutoff.
I do believe the AHJ regulates this and it may be different in each area.
kmcmahon wrote:
Most furnaces have a shutoff switch for servicing, however today I had one that was just plugged into an outlet. Is this ok? Can't find anything on it. I've never seen one just plugged in before, but I suppose you can just unplug the unit for servicing.
Standard, forced air, gas fired furnace? That's about all we have out here and they are never equipped with a shut off. Just a plug to a receptacle.
-- Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: rsummers This post was automatically imported from our archived forum.
It must be a California thing Jeff I have installed a couple of thousand furnaces in my neck of the state and they are all plugged in with a 20 amp cord.
