This is a fun one! How many things can you find wrong with this scenario? This is a garage stairwell going down to a wooden entry door which goes to the basement. This is the only way from the garage to the dwelling.
Lack of handrails,landing and drain are the first things to jump out at me.
Irregular stairs certainly hurt also as a trip hazard.Hmmmm fumes like to sink do they not? (screen door only)?
Should not even bother with the power strip after all that so will not mention it.
Dang John is this a old picture as those look like autumn leaves ? (see the date) lol
Knob is almost in the wall, I assume it opens in ? Right, any stops on it whatsoever ?
It looks like it was swinging out, if thats the case, it sure as hell aint openin is it ?
How many would really call for a drain at the bottom of the stairs? Now normally basement exits that are below grade and exit to the “exterior” would require a drain. Does this really exit to the “exterior”? I am assuming the garage is fully enclosed and there is no threat of rainfall and water coming off a vehicle is minimal so would this truly require a drain?
