Gas Leaks
Originally Posted By: Brian George
I’m not inspector(yet),but service gas equipment.
Pilot tubes are a good place to ck but other wise if lines haven’t been moved don’t worry unless smell is present.
When you ? over sensitivity of meter use soap bubbles on joint so you can understand the size of leak and weather theres anything to report.
Originally Posted By: pdacey
I have a Tiff 8800 but seldom use it. I use the old nose first and then the TIFF to pin point a leak if I smell gas. I also carry a small squeeze bottle with soap and water.
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
www.southwestinspections.com
Originally Posted By: wpedley
So what do you do when you "smell’ gas and you can’t necessarily
find the leak but you notice the smell only while the power vent is
running. After about 5min you feel funny. This system also has a gas water heater. Vented through the same power vent?
BPedley
Inspecting for the unexpected
