Originally Posted By: ssmith3 This post was automatically imported from our archived forum. Most gas shut-off valves are behind the stove. Normal location around here.
– Scott Smith
Marinspection
Vice President NorCal NACHI Chapter
I graduated from collage. Now my life is all mixed up.
Originally Posted By: mike garcia This post was automatically imported from our archived forum.
sctt , do you know if this is not a code violation because you should be able to turn it off in case of emergency. doesn’t make sense you can[t get to it.
Originally Posted By: Blaine Wiley This post was automatically imported from our archived forum.
The local requirement here (for homes built since 1998) is that the gas valve must be located behind the stove at least 30" from the floor. It was the same in VA.
