Geothermal
Originally Posted By: dmacy
I could use any helpful information pertaining to geothermal heating.
Inspection techniques.
Potential problems.
Advantages vs. Disadvantages.
Web links.
Thanks
Dave
Originally Posted By: jhagarty
http://www.waterfurnace.com/content.aspx?section=residential&page=video
Joseph Hagarty
HouseMaster / Main Line, PA
joseph.hagarty@housemaster.com
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Originally Posted By: dedwards
Dave,
Go to Google and type in Geothermal HVAC. You will get way more than you ever wanted to know about Geothermal systems. The University of Okalahoma is probably the front running authorty on Geos and have been the research for years. The inspection isn’t much different than that for an air exchange heat pump (only uses a different medium) There isn’t an outdoor unit to inspect. The indoor unit is typically larger than what you are used to. Most of the bigger makers have sections on geothermals as well.
