Never inspected a Geo-Thermal unit. Any links, advice, instruction, etc. Have one today that I was under the impression it was typical GFA. Surprise, Surprise!
Thank you in advance,
Randy
I’ve got all sorts of links for Geo-Thermal education. Basically, simply check for adequate heating/cooling and report your results.
1) **About Geothermal by: Cornbelt Energy **](http://www.cornbeltenergy.com/geotherm.htm)
**2) Geothermal Resource Council **
3) US Department of Energy
Energy Efficiency and Renewable Energy](http://www1.eere.energy.gov/geothermal/)
**4) Geothermal Heat Pump Consortium **
5) Energy Information Administration
Official Energy Statistics for the US Government](http://www.eia.doe.gov/)
Excellent David, I will add these to my library. Is there any other items I should be looking for? Is it okay to operate in both modes?
Thanks again,
Randy
I do not inspect A/C mode if weather is under 65 degrees. Make sure you note what you did and did not inspect and why.
I inspect heat in both hot and cold weather. Some inspectors (here) may have issues with inspecting heat in the summer months, but I never had problems with this.
Thanks David for the links and advice
Here is a link, they make a pretty good unit and the site has lost of info.
http://www.waterfurnace.com/
Some one will be along soon to comment David that is why I like this place.
