I have a GFCI breaker with a jumper wire between the neutral ports. Never seen a configuration like this. Also, the back “panel neutral” has 3 wires (which I’m sure the breaker is not rated for). Any idea why this would be done this way or any documentation to show this is not acceptable?
I’ve never seen that either. But when I look up the breaker, it’s configured that way from the factory. It appears to be obsolete and people are asking $200-300+ for used ones.
I stand corrected. Evidently using the Cat No. QF115 in my search was not providing the correct results.
I did find one that is much cheaper Ebay
Also found during re-searching, the seimens breakers I posted above are listed for replacement…just in case someone wanted to know.
