I did inspect this house and came across to a GFCI outlet that has it’s green light is always on.There is power downstream,it reset,test button work.My question is, is this normal or faulty outlet?
Several years ago there was a manufacturer that put the green light in the gfci’s to indicate that they were grounded. (Leviton?) So a steady green indicates it is grounded.
Not really. Just some models. It will illuminate green when it’s wired properly, and switch to red if it trips. I installed some of these in the early 90’s, and I believe that they were the Leviton brand.
