Originally Posted By: jacaron
Dennis missed us. We are blessed.
Originally Posted By: mcyr
Originally Posted By: jwortham
Originally Posted By: gbell
Greg Bell
Bell Inspection Service
Originally Posted By: vsantos
Originally Posted By: bsumpter
“In the fields of observation, chance favors only the mind that is prepared”
Originally Posted By: tpope
Timothy Pope
www.craftsmaninspections.com
Austin, Tx Home Inspections
Originally Posted By: lewens
Just my usual 12.5 cents
| lewens wrote: |
| Vince
I have to disagree with you. We, as home inspectors, have an obligation to reflect on all aspects of the home both good and bad. The potential buyers are going into the most important buying decision they have ever made and usually cannot see the forest for the trees. They only know that they like the home and can see themselves living in it and making it their "home". They are essentially blind. If you and I don't go in to the inspection with open eyes yes, but more so with an open mind I believe we are doing a disservice to our clients. The want to know what is wrong with the house yes, but they also want to know what is good about the house. If it has a new roof just installed do you say "roof is in good condition" or do you say "roof has been replaced within the last two months and the quality of the installation and product used will give you many years of trouble free service with regular maintenance and care". Likewise is the furnace in good working order or is the furnace in good working order and appears to have been regularly serviced by qualified people in evidence by the inspection tags and repair log kept between the intake and exhaust plenums. Potential buyers want to here about the good stuff as well as the bad stuff. They want to know why they think they have made a good decision. If they have made a bad decision you will definitely let them know but if they have made a good one you should also point that out. Just my 12.5 cents Larry |
Originally Posted By: dandersen
Originally Posted By: hgordon
| Quote: |
| This property is with-in close proximity |
| Quote: |
| This is an overzed home |
| Quote: |
| to prevent a shot down of the serviced water |
| Quote: |
| It must be noted that roof structures often contain hidden defects and that if this is a cause of concern, a state of Florida licensed roofing contractor should be brought in, to further assess the condition of the roof. However, it was noted that the roof structure appears to be solid and in good condition. |
| Quote: |
| It is apparent that the property has gone through a few renovations, maintaining the structural integrity and design of the original structure. The large hip style roof area in this house is quite impressive. However, it is normal in houses of this age (+/-32 years) a minor wave pattern in some areas throughout the large front surface of the roof. Age, time, wear, settlement and sagging of the sheathing can cause this phenomenon during the years. |
| Quote: |
| Consideration should be given to the following:
1. The large roof surface is quite impressive. During...however, this house offers a tremendous opportunity to increase the energy efficient characteristics of the home...In general, the roof appears to be in good condition. |
| Quote: |
| Roof:
...These shingles have dried and cracked, loosing a large portion of their rock granule cover. If left on the roof, theses shingles will need to be replaced within the next 2-3 years. Roof leaks are present on the Northwest valley, the Southwest valley, the chimney flashing and at the basketball goal attachment to the home on the South side of the property. All roof leaks have caused moisture damage to the roof decking in their respective locations. All damaged decking and shingles in these areas should be removed and replaced...The roof ventilation is incredibly inadequate for the size of this roof. This lack of ventilation has caused the roof trusses to bow and twist, and caused some delamination, of several sections of the roof decking. The areas of the roof decking that have bowed are at risk for holding water and causing further damage to the home. (Evidence of reverse heat flow is present at the interior exhaust fans of the home in the form of dust and debris along the ceiling.) |
| Quote: |
| SHOULD I TAKE MY CLIENT TO THE CORT TO GET PAY?? |
| Quote: |
| It is the opinion of HOMEINSPECTORUSA, LLC that the subject property in general, appears to be in good condition. |
| Quote: |
| This inspection will be stored in our database for 30 days after issued, thereafter will be discarded. |
Harvey Gordon
SE Florida NACHI Chapter - President
hgordon@fl.nachi.org
Harvey Gordon
