bcawhern1
(Brian Cawhern, CMI®)
May 30, 2021, 4:07pm
52
If you think you should ignore @jjonas because you are in your “feels” then you are going to miss out on some good information. Here are a few recent posts that will help many people:
NO, two-prongs are NOT a defect.
Three prongs without a ground IS a defect. That is what the posted Nachi SOP is referring to.
Wow, just wow!!
I can’t believe after other threads discussing this that ya’ll still get it wrong!!
[c087d6ce25956151b20c225e52517a922d113ba7]
The primary issue here is that the NG DOES NOT flow OVER the opening to the “leg” to deposit any debris or moisture. IMO, there are two methods to correct this set-up.
move the leg to the other side of the Tee (where it should be),
or
increase the slope of the horizontal run (to furnace) to at least a 45 degree angle (redneck fix).
The current set…
https://forum.nachi.org/t/propane-tank-regulations/198676/8?u=bcawhern1
Consider this…
Supply is under pressure, waste is not. How do you think they react to this? The same? Differently?
Until you sign up for a Business Account, you WILL NOT see the actual cost to you. I pay less than half for the products shown on the site, and I NEVER use the USPS mailers or FREE shipping from anyone on “Time Sensitive” products. RTCA has a policy of results back same day as received. I always ship out same day as picked up and using Overnight service. This equates to results back the NEXT DAY! Very rarely did the deadline get missed, usually from weather conditions disrupting shipping.
http…
