Originally Posted By: jwortham
Had an inspection yesterday that has me wondering.
Ground rod has an acorn clamp with a red wire being used as the ground wire. It goes underground.
The ground wire coming into the panel is black. It is tied into the neutral bus bar.
Ground and neutral are tied together properly through the panels bonding strap.
Every wire on both the ground and the neutral bars is white.
Other than the wire colors being used, is this an issue?
thanks.
[ Image: http://www.nachi.org/bbsystem/usrimages/more/P1010058.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/P1010063.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/P10100121.JPG ]
