Years ago, we brought up to Dominic/HIP that when we take TI pics we would like a way to line them up side by side in the report. He then added a feature/update in the next version of HIP.
You can click on the pic and then click the up or down arrows to move the pics where you want, then generate the report. Then we mentioned to Dominic that when you have many pics it takes too long to click through all the pics so he added a scroll bar which was much faster.
Last week I tried adding TI pics and the up/down arrows option did not work, only the scroll bar option worked.
So my question is, is anyone else having the same issue? Is there a work around? Am I missing something? I just wanted to move the TI pic up two clicks but the scroll was racing up and down and out of control…
Hey Mark. Recent versions of HIP use Tab and Shift Tab to flip back and forth. You can change that behavior under the Applications tab.
As Jeffrey mentioned, definitely tag me if you have a question or just ping our support! We are the only ones in the industry with phone support 24 hours a day. Or use the Live Chat or ticket system. We have a dozen tech support team members there to help you out!
in applications - I see control + tab forward?
Tab and Shift Tab to flip back and forth - not sure what this means…
Thank you, Mark and Gina Timpani
Pride Property Inspections
520.907.9335 CERTIFIED MASTER INSPECTOR
"If you think it’s expensive to hire a professional to do the
**job, wait until you hire an amateur."**Red Adair www.pridepropertyinspections.com
http://www.tucsoncommercialinspections.com
https://tucsonthermalimaging.com/
Those keys let you switch between the photo tabs. Give the office a call and we can walk you through it 888-750-4777
thank you
Since you cant choose a photo and use the blue up/down arrows - are they going to be removed in the next update?
thank you
Maybe I’m misunderstanding, which buttons are you referring to? In HIP 6 the rearrange photos is drag and drop on the slideshow view. The arrows are to move comments between summary and not summary. Is that what you’re referring to?
see attached pic
Those are for the narratives to the left.
