H/W gas heater
Originally Posted By: cobrian
http://www.nachi.org/bbsystem/usrimages/b/bc.jpg ]
[ Image: http://www.nachi.org/bbsystem/usrimages/c/cb.jpg ]
[ Image: http://www.nachi.org/bbsystem/usrimages/d/dc.jpg ]
This is in a garage closet with no visible combustion air return. And not 18 inches off floor.
Could it be a sealed combustion chamber and if so can you tell with out removing cover?
FNG so be nice.
Originally Posted By: dvalley
No, this is not not a sealed combustion chamber.
Yes, this w/h must be 18" off the floor in any garage installation. It appears to be placed on a 3 1/2 inch platform, so 14 1/2 additional inches is needed.
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: gbeaumont
Hi to all,
Chip, from what I can see from the pictures the installation would not meet current codes, both in terms of combustion air supply, and also as you state insufficient height above the garage floor.
Are you sure there was no other air supply inside the closet ?
regards
Gerry
Gerry Beaumont
NACHI Education Committee
e-mail : education@nachi.org
NACHI phone 484-429-5466
Inspection Depot Education
gbeaumont@inspectiondepot.com
"Education is a journey, not a destination"
Originally Posted By: whandley
It looks as though the closet/enclosure was added around the unit. Is it possible the unit was relocated to the garage from an interior portion of the main structure? In either case, simply removing the door will in most cases provide sufficient combustion air for residential water heaters of 75 gallon and smaller capacity located in a garage. I also agree, the unit is not properly elevated above the interior slab surfaces.icon_idea.gif
I see you edited it from “visible venting” to “visible combustion air”.
A louvered door will also work.
David Valley
MAB Member
Originally Posted By: Heath Brier Johns
So does that mean this w/h needs to be raised and add a louvered door?
[ Image: http://www.nachi.org/bbsystem/usrimages/Y/Yother_photo_page_018.jpg ]
Originally Posted By: dedwards
When was the home built? I too am in the Panhandle of Florida and I see water heaters in MOST garages and many if not most older ones do not have the WH built up off the floor to meet the 18 inches requirement because that was not a requirement at the time of construction. Typically we see all kinds of things that are either not “code compliant”, unsafe or poorly installed at the time of construction. Just from looking at this WH I know it is not a recently built home. Here is where you have to advice your customer in particular what is safe and what is unsafe while avoiding the dreaded “C” word (code). I personally often tell them that something that was allowed at the time of construction no longer is allowed by code. GFCI is a perfect example of a safety item that I routinely recommend upgrading to if not present or required at the time of construction.
Originally Posted By: jkormos
Yup ==> icon_biggrin.gif So does that mean this w/h needs to be raised and add a louvered door?
Joe,
A simple recommendation will suffice. Observe and report. If they fail to take your advice, it's not your problem.
David Valley
MAB Member
House was built in 87.
No visable air combustion venting.
was built this way.
Originally Posted By: wdecker
I would recommend a louvered door, an increase in the platform and the installation of a CO detector in that room, to guard against any backdraft.
Will Decker
Decker Home Services
Skokie, IL 60076
wjd@DeckerHomeServices.com
Thanks Guy’s
