I have a thread up in IR and discovered some folks don’t understand the refrigerant flow in a HP I am of the opinion that if one is to inspect a system even if its just operating it you should at least understand the basic principle of operation.
The above link indicates the flow of a heat pump it just shows basic items no extras. No dryer/filters no accumlators but it does indicate the state of the refrigerant as to liquid or vapor
I took the day off (and I didn’t even have a beer last night!)
A zoned system is 2 t-stats, one unit.
If so much as a damper actuator does not fully open, it will not work.
Don’t wast your time trying to figure this type of unit out.
Even the HVAC guy may not get it right…
jhorton1
(Jim Horton, State License #HI01100033)
#12
I called my customer today and he has an electrician/hvac and plumber coming Friday, and invited me to the party. So hopefully I can get better educated on this system.
The main reason I asked was that on our service calls (other job) , when unit was off from someone going on a trip and returning, and informing that unit will not respond. Inform them that it can be from 10-30 minutes for it to crank up. Also this happens to the newer refrigerators, and other appliances. Computer board parts etc. need to warm up ! JUST SAYING…
Happens that I am familiar with heat pumps as I have one and have inspected quite a few in depth. I do know quite a bit about HVAC.
I would imagine it was an Air based system and not Water like mine though.
Yes, any one stat on the zoned system should have turned the blower on regardless if the Heat Pump/AC was working or not and the appropriate damper for that zone or both dampers should have opened.
With the house being vacant, and I do believe it was, could they have possibly turned the power off to the unit? I would imagine you checked the breaker.
Anxious to hear what the outcome of your meeting was.
jhorton1
#18
Hey Michel,
The HVAC guy fixed an issue with one of the thermostats, and said a _____ part needed to be ordered. The customer couldn’t remember the name of the part, but no place had it in stock.
We are waiting for this part to come in and hopefully find out more.
Appreciate your input and concern…I’ll keep you informed…
jhorton1
#19
Hey James,
Sorry, over looked you. That’s good information to know. That’s good enough information you should charge for it. Oh wait…you do…
This is an ongoing ordeal. I’m anxious to find out if this 1987 unit is going to fire up.
