Holes above flashing?
I haven’t encountered this yet. This is where the wall of the roof over the entryway meets the main roof. I thought they were weep holes at first, but why are there so many? If not weep holes, what are they? It’s only on one side too, not the other.
Weep holes
I would be cautious and investigate it a bit more. Can’t really tell from pics, but to me they look drilled. Do they look like drilled holes added after the brick cladding was installed to you? If so, they may simply be ‘‘ventilation’’ holes at this point.
And with that said, it could be an issue or consequence on down the road or could be nothing. But if they do in fact appear to be ‘‘drilled’’ I’d document it in my report.
Somebody thought they were smart and installed “weep holes” above the flashing. Only problem is…the counter flashing only goes into the cut line in the brick, it does not lap back up the wall normally. The weep holes are now allowing water to enter the wall cavity and get under the flashing.
I would say improper installation of possible weep holes. They will not be effective in this position, unless they did something behind the brick, like run the counter flashing up to make a drain plane at this elevation. The area has clearly seen recent work, likely due to moisture deterioration and/or moisture intrusion, and they were thinking putting holes in this location would prevent it in the future. My recommendation would be to plug the holes. Weep holes should not be needed in that area.
I would be slow to make that recommendation. I lean more toward reporting something like, “Holes of unknown purpose drilled above flashing. Recommend Getting the explanation from whoever did the work as to what they were trying to do.”
Not a bad approach either.
Observation: Entranceway Masonry sidewall at sloped roof intersection.
Suspect: Sidewall flashing. Appears to be 2 lengths of ridged sheet metal flashing. Bottom flashing has a 1.5 inch outward bend/break. Counter flashing on top.
No visible step flashing.
Sealant or plastic cement atop both lengths of flashing.
Masonry: Drilled holes in bed and butt mortar every ><8" diagonally above counter flashing.
Hypotheses: Likely drilled for taller sheet metal counter flashing.
Recommend a licensed roofing contractor further evaluate and improve areas of concern.
Immediate.
Act upon any recommendations therein.
yea, that one odd installation, both for the penetrations and flashing as well. Definitely something in the DIY range, like others said possibly because there was leakage noted in the attic or down the chimney or something similar. I will often use “unusual installation noted, explain what is unusual” and then recommend evaluation by qualified roofer or masonry professional for further investigation and discussion for resolution if required in cases like this. Primary because you don’t actually know. like @ruecker said, they COULD have put flashing all the way through the inside brick layer, and then the weep holes would actually be proper(ish, even if weird) in this case. ! Certified Okanagan Home Inspector
