Hi i live in California. We just got solar panel installed. The inspector is going to come by to make sure everything is ok with the installation. But for some reason he also wants to come in and check all the fire alarms inside my house in every room. We do not rent and this is my home i have been living in for the past 15 years. Is this normal procedures for the inspector to check to my fire alarm’s in my home. Due to the solar panel installation. Before i tell him No nicely. I want to get my facts and rights straight. Thank you.
Call the building department for an explanation.
are you referring to smoke alarms there is a difference between the two.
What “Inspector” are you referring to?
The City?
The Manufacturer?
The Distributor?
The Alarm Company?
I am assuming the local AHJ, and as you probably need a Permit, and there is probably an Ordinance for smoke detectors in your local area, YEP… gotta let em in… and expect to install smoke detectors where necessary… or NO Permit!
I am not renting. I have been living here for 15 years. Yes smoke alarms. I am going over the contract and also going to contact AHJ. Thank you.
