Hello to all and happy weekend!
Looking for advice/input, all points of view welcome.
Just did a home inspection for a semi detached where the neighbor had an electrical fire. Supposedly the owner’s insurance company came in and cleaned everything up (which they clearly did not) and put it back the way it should have been.
What they did do
Replaced the insulation in the attic (party wall is masonry, no other coverings)
Cleaned the underside of the roof sheathing
“cleaned” the house (without even removing a thing from any wall or any of the contents or soft goods)
put in 3 indoor air scrubbers (HEPA)
drilled some 4" holes in the common wall - which is nothing more than drywall on 1/2" strapping over masonry, no isolation to do “air testing”
What they didn’t do (this is where i’m looking for input)
Paint anything, inside attic, walls, nothing (no visible smoke damage)
Remove anything from any wall or wash walls with TSP
Remove contents
Tell homeowners to discard open food
thermal fogging
ozone generators
etc…etc… I don’t even know what should have been done to this point.
When you open the front door, you can still smell the smoke, its pungent in the kitchen, which was the closest room to the fire, no cabinets were removed, no contents, etc.
As soon as you walk over to the neighbor’s place (windows open) you really smell it.
I’ve never been asked to deal with this before and want to be careful about my liability.
I ran Indoor air quality tests on all floors, noted the pungent odor and even left the place hacking up phlegm, so there’s an issue for sure, but insurance says the IAQ is “OK”, when clearly, there is an issue.
Anyone ever dealt with this before and is there a standard protocol for what do to after smoke damage/smell.
Should i defer them to a fire restoration company for 3rd party independent reporting on what to do with the smell?
Any and all advice is appreciated - except for someone telling me to put a bowl of vinegar in the kitchen ![]()
Thanks team!
