hose bib between 2 egress window wells
Originally Posted By: psiposs
The hose bib is located between 2 egress window wells. Getting to it is a bit awkward especially when the plant nearly in front of it is obstructing it.
Is this something I should write up? And if so, how?
http://lexam.net/carnut/misc/hose1.jpg
This is for a mock inspection.
Originally Posted By: psabados
Peter
Those wells look awfully deep. No safety rails installed to prevent an accidental fall into the well. Hopefully hand rails on the hidden from view side. Is that a wooden retaining wall?
Paul
NACHI Vice President
NACHI Foundation, President
Convention Coordinator
Originally Posted By: rmoore
Peter,
I wouldn't. You'll get to see hose-bibs "buried" behind much more mature shrubs. If it's functional, without any other problems, and can be reasonably accessed at all I'd let it go. I'd imagine someone mowing, or simply walking in the yard, would be more likely to break a leg in the unprotected wells than when they are facing the wall using the bib.
I might verbally suggest that my clients don't water at night after a few drinks though!
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Originally Posted By: bkelly2
Can not tell Peter, is there an anti siphon valve on the hose bib?
“I used to be disgusted, Now I try to Be amused”-Elvis Costello
No there is not. Its the sort of bib where the valving is done a foot inside to prevent freezing.
PS
PS
What is this, freezing, you speak of???? ![icon_cool.gif](upload://oPnLkqdJc33Dyf2uA3TQwRkfhwd.gif)
"I used to be disgusted, Now I try to Be amused"-Elvis Costello
A condition not often known in the southern states icon_smile.gif In the pacific northwest where I live, there are 4 seasons which provide a beautiful changing appearance of the area through-out the year. Freezing is the result of tempuratures below 32F or 0c and water in which is frozen. We had 23f last night briefly but the sun this afternoon is giving 43f which means no ice left over from last night.
icon_smile.gif All in jest!
Quote:
Phoenix, Arizona
87?F at 4:02 pm
Forecast High 90?F / Low 65?F
