Identifying hose bib, frost free or not?
What is a sure fire way to identify if this hose bib is frost free or not?
Not frost free. Valve seat is located outside.
Valve seat outside:
Valve seat washer inside:
The easiest way is to look for a horizontal valve assembly with a vacuum breaker on the top just like the one @lkage posted.
What you pictured is
The vacuum breaker is also called an anti siphon valve or siphon breaker… Many different names…
Also note, this type of bibb, (when properly installed), will typically have a slight downward angle to drain any water from the stem to prevent freezing in cold weather. Improper installation is common, and should be reported when observed. I have seen many that did not drain out the excess water, and froze causing the pipe sleeve to burst!
