I am sure there is a good explanation for this, I have just never seen it before. This hose (garden hose) goes from the copper plumbing piping into the floor drain. Sorry the one pic is sideways, I can’t figure how to do it differant. The house has a newer A/C and furnace. What is this hose for?
The draincock that the hose is attached to may be to back drain the line from the shutoff valve to the vacuum break on the outside of the house to prevent freezing. Hose is just a convenience to get the draining water to the floor drain.
I agree with Larry…if the home has U/G sprinklers, I see a lot of folks doing that for two reasons. One as Larry suggested, and the other is because the Main Gate valve to shut down the U/G’s for the season, isn’t holding. It allows a dribble to pass by the shut off valve and this is a way of letting the seepage to go to the drain, instead of having to empty buckets or letting the lines fill up again over the winter months and freezing/breaking a line.
