Found this in crawlspace of split ranch. 1962 and connected to a galv supply pipe.
Pipe appeared to head from outside front bib to rear kitchen sink area.
wall it enters is other side of 1/2 bath and wall after that contains stack pipe in basement utility room.
Thanks for any educated guesses.
I need to go inspect for now.
Was it used to build pressure to move the water -> inward? Was there an area outside to "WASH the tractor? Are you saying that someone is consuming this water even though it flows through the dissimilar piping? [galvanized and copper]. What say you?
From your pictures, it doesn’t appear that the hose terminates in the crawl. Actually, you said you didn’t have time to trace it out.
Logic says that if it did indeed terminate in the crawl, you wouldn’t be wondering wher it went. :shock:
Well, like I have seen in the past, they wanted an outside hose bib and could not afford the plumber, and have also seen where a washing machine was added and fed with a hose.
Does it really matter what it is for? Yes, I would be very curious and would have probably looked for the other end for a couple of minutes, but in the final analysis, I would just write it up and make it a “red” comment.
