I have moved a wall and now my 4 (I think) AWG wire coming from my hot tub is not long enough to reach my panel. What is the best way to connect this size wire to another shorter piece so that it will reach the panel along the new, longer route? I do not want to pull all new wire if I do not have to. Can I just add another panel or are their “wire nuts” or something similar that will suffice?
Since you appear to be a contractor you should know to hire a licensed contractor to fix this for you. They will have the knowledge of how to properly fix this.
What you are looking for is the addition of a junction box if your local code permits. When you call your electrician tell him you need a junction box or two installed. That should get both of on the same page. Just make sure that the junction boxes are accessible when all is finished.
This is not a DIY forum. No offense, but if you are a contractor you should be well aware of at least the methodology and correct terminology involved.
Roy, don’t forget… with some larger conductors, they use aluminum. The stretchers need to have the torque set for the proper type and size conductor or you can run into trouble. I use a metric one since it seems to match all the foreign wire coming into the country.
I always keep my wire stretcher right beside my wood welder. If I have a wire to short, I stretch it. If I cut a 2x4 to short, I weld it back together. Simple fixes.
I need one of thsoe 2x4 fixers ,I cut A 2X4 last night twice and it was still too short .
No longer working at the trade I gave away or through out a lot of old equipment .
I wish I had my lead dip pot my one lb soldering iron and my Glyptol paint can to show how we did joints in Knob and tube .
We also had 25 cycle back then .
It really showed up on Florescent lights
You could…and let’s say he harms himself. A good investigator could track it back and if liable for poor information then…well you know. Also this is for Home Inspectors…not DIYers.
Just my opinion…and I have helped a lot of people over the years on DIY sites…here I only guard against it for the sake of the HI…just my opinion.
I have turned away from the DIY sites now. I am a verified contributing electrical expert on the largest help site, but anymore there is just to great of a risk that the poster either misunderstands or cut corners intentionally.
