Some plumbers are not very clever.
You are supposed to install equipment as the manufacturer intended. Water heaters heat water most efficiently when the water is going through them as designed.
You are not going to trick me into telling someone how the internal piping of their water heater looks/works without me seeing the the manufacturers drawing/schematic.
…or they’re actually drawn sideways–both units are installed horizontally with an exhaust fan in the chimney drawing the flame into the heating tube and out the chimney…
Plumbers cracks are what is seen from behind when they are squatting down. :mrgreen:
Sorry, Jae. Had to do it.
I have, recently, been running into a some of fmy ormer clients who call me to complain. They have HVAC guys come in to do maintenance on their furnaces (most that I inspect have not been looked at in quite a while and I recommend maintenance) and they tell the client that the water heaters are spewing forth CO. Of course the client panics and the HVAC guy is right there to slap in a new water heater.
In my area, water heaters are a plumber’s job, not an HVAC guy. What about in your areas?
The clients are, usually, quite P*SSED and want restitution. I have been called back a few times when the HVAC guy was still there and re-inspect the drafting and such, but find nothing. The HVAC guys are usually really indignant. “Who you going to trust, a home inspector or an HVAC professional”, they say. Puts the client in quite a bind. I usually refer them to a good plumber who comes out ans tells they that everything is OK.
I saw a great termite inspection today. The termite guy got there 15 minutes after me, talked with everyone for 15 minutes, said the house had to be tented, and left. Hmmmmmmmmmmmmmm. His company is now on my “Do not recommend” list.
