mkincheloe
(Mark Kincheloe, HIO1400089, IL 450.011908)
Both lines are hot to touch, doesn’t seem right because the right side with the shut off is the supply which also leads to the water softener . That line is also warm not hot as it feeds to water softner
I’m not a code enforcement person but I also know that it’s not right to run flex straight to the water heater.
Photo in Attachment
I think if you go to the sink and turn on both taps ,Then check the water heater pipes you will see the cold is now cold .
I think it was not used and the tank heated the cold supply .
Note the proper name is water heater not Hot water heater .
I posted the picture so all can see the tank correctly . I see nothing wrong with the flex pipes .
What is the hot temp at the taps .
