A 2004 Bradford & White water heater has a pressure valve off the hot water copper line above the tank with a small diamater line extending to the ground.
Should this valve be removed? If yes why? If no how come?
Does it go to a floor drain? Looks like a primer.
Did the tank itself have a TPR valve installed correctly?
TPR valves shall not have the discharge size changed and must run in Canada down to with in 8 inches of the floor. Cookie
That relief valve is worthless.
Jason asked the important question.
Yes, the typical relief valve was installed.
Would you advise removing the worthless one?
I would, doesn’t make much sense…
Maybe the installer thought it would make a crude air arrestor???
weird…
It’s an unnecessary component, subject to failure over time. It would be fairly simple to just cap it off, which would probably be my recommendation. . .
