A sliding glass door was observed on the second floor with no deck, balcony, or guard installed. This condition presents a potential fall hazard if the door is opened. Recommend installing appropriate safety measures such as a guard, railing system, or door restrictor to reduce the risk of injury. Hope this helps
A door stop should be installed when a patio door leads to an area where a deck or landing has not been constructed yet, or is currently under construction. This prevents an occupant from accidently stepping out the door. The stop should be installed so as to limit the door to opening less than 4 inches.
Recommendation: Consult with a qualified contractor to install a door stop. The door stop should remain in place until the landing/deck is completed and ready for use.
You’re saying it’s right at 7 inches or 7 feet? Just recommend a guardrailing or fixed door stop be installed. It’s pretty common to see tract homes with second story sliding doors and no deck yet. They just put a guardrail across the opening.
There isn’t in my opinion. There could be many defects and deficiencies hidden in plain sight.
I have inspected countless sliding doors without a balcony or deck present.
and that wasn’t the question. the question was how to write up the door to nowhere. that doesn’t need a picture to write up. if you need a picture of the door to nowhere to figure out how to write it up…
To protect yourself and help your client a word like “permanently” is appropriate.
A sliding glass door that opens to free open space exists in the xxx. A proper deck or stairs/landing should be provided or the door should be permanently secured closed to prevent an injury or fatality.
