I get all my drinking water from a local well, I can’t stand the taste of municipal water.
If I were in your situaton, I’d install a filter at my kitchen cold water supply only. Your hot side supply gets boiled anyways and this boiling of water will be suffice.
I have a standard carbon filter w/separate tap at the sink for all our drinking water. Works great for chlorine and other contaminates typically found in municipal water. Undersink RO’s work great too, a bit expensive, but worth it if you find yourself buying a lot of bottled water.
Dave…check out the PUR 3 stage system…available in home centers…attaches right to the faucet with easily replaceable cartridges…turn to use turn to by-pass…the wife fills a pitcher and keeps it in the fridge …their literature is quite impressive and You can be up and running in 15 minutes for less than 100.00…Me i drink the plain tap water…Lake Erie water tastes great…anyhow a good inexpensive way to get started imo…jim
as Dave is in the next county over, i’m not sure how it is there but here in Lorain county we get a water quality report every year…very extensive and our water tests as good as many of the bottled waters we are all spending our money on…jim
Good luck finding credible support for these things. they might do something but they don’t remove the Calcium ions that cause the hardness in the first place.
Thanks Micheal…I had not heard of this system before but as hard water is not a problem here i have not done any research either…sure looks a bit funny though…probably not to those people that wear the magnetic bracelets though…jmo…jim
In the interest of full disclosure, I used to work for Ecowater when it was Lindsay over thirty years ago. My dad installed softeners for them for many years.
I have always had a softener installed in my homes as once you get used to 0 grain hardness water everything else feels different and scummy.
A lot of detergent is required to make hard water suds up. Soap will suds great in soft water but not at all in hard water.
I have a relative who spent several hundred dollars on the magic magnets and they wouldn’t give him his money back.
He got to spend hundreds more for a real water conditioning system.
You can pick up simple hardness test strips at several retailers.
I’m sue your right about many of the “free” test you water outfits.
They are there to sell their product which has a fat commission built in.
That by itself doesn’t make them bad but I’m sure there are plenty of scammers.
