"How to Perform Mold Inspections"
Pull down ladders for home attic entry can be a great way to access an attic. Care must be taken before climbing up a ladder to make sure it is safe. Inspect for proper attachment to home by noting if screws or nails were used. Always use caution while climbing up attic stairs for the first tim.
The soffit on the east side of the building has apparent moisture stains. The moisture is most likely coming from a cut in the roofing membrane located above the water stain. Moisture intrusion is the primary cause of mold producing conditions. Recommend evaluation and correction by a qualified contractor.
I read the article, Mold, Moisture and Your Home. The article was primarily targeted to the consumer audience rather than an inspector. The clean-up section provided good guidelines on the appropriate approach to different size mold problems. I think this article would be a good article to pass onto clients.
logging into course
This picture is of an unfinished portion of a basement in a one family home. The water stains on the base of the framing as shown is evidence of past water intrusion. There was no damp or musty smell in the basement or signs of current moisture damage. This was sign that possible mold growth could have been present but not currently visible.
The image examined for this essay was attic condensation-2d. The presence of any moisture especially in a warm and humid space that an unventilated attic space presents is an invitation to mold. the warm air leaking in from light fixtures that penetrate the ceiling below and the cold surface of the roof exterior creates condensation and results in moisture. Moisture plus the surface of insulation and wood rafters are perfect for mold growth.
Since i wanted to know more about afci, i went to afci testers. I learned that they are expensive, that they are ineffective, and not widely used. This left me at about the same position i was in before reading the article.
I RECENTLY HAD A PROJECT THAT HAD MOLD, BAT GUANO, LEAD AND ASBESTOS THAT WE KNEW TO BE IN THE BUILDING. I COULD SMELL A MUSTY ODOR IN THIS PARTICULAR ROOM. I HAD MY GUYS TEAR THE WALLPAPER BACK AND THIS IS WHAT WE FOUND.
Bulge in the belly was a picture I looked at showing us what can happen when your tub has a pipe leak, failed seals, or water splashing out of your tub. If you have a bad seal water can leak into the floor. If you have a leaky pipe water can collect under the tub until your floors or drywall become saturated with water and bulge until it burst. In my case I had a slow leak and overtime I developed mold throughout the floor joist, sub flooring and up some wall studs and not to mention a hole in the kitchen ceiling below the tub. Turned out to be a gut job and emptying the savings.
The photo appears to be an example of one of the most common types of mold found in homes in areas prone to moisture - Stachybotrys chartarum, sometimes referred to as "black mold. Chronic exposure to black can cause health concerns.
The article I chose from the article library is entitled: "Air Sampling for Mold Inspections by Nick Gromicko and Ethan Ward.
The article talks about taking air samples via special pumps that captures mold spores for further evaluation by laboratory analysts.
My essay is on duct system’s in the house. Our house is 35 years old and just got its first upgrade to a new heat pump and air handler. We have had lots of pets over the years and for as long as I know, my wife has suffered from allergies and sinus problems. A few months before we had our system replaced I had problems breathing. Come to find out we had condensation built up in our ducts and developed mold and the system was very dirty due to a faulty air filter housing. Short story is we got everything cleaned up and working right and my wife and I have had no breathing issues or allergies.
Review item. Inspector observed a leak under sink. A pan has been placed under the drain lines to catch water. Below the pan, the inspector discovered initial signs of mold. Recommend review by a qualified professional for repair or replacement, as necessary.
I learned about several types of devices used to collect air samples that can be analyzed for mold.
An inspector might use an 1) impaction sampler that uses a calibrated air pump to impact spores onto a prepared microscope slide;
2) cassette samplers, which may be of the disposable or one-time-use type, and also employ forced air to impact spores onto a collection media; and
3) airborne-particle collectors that trap spores directly on a culture dish. These may be utilized to identify the species of mold that has been found.
After researching for the proper equipment that can qualify to do a proper mold inspection as outlined in the IAC2 Mold inspection check list and SOP I came across this in the inspector outlet store and was immediate drawn to purchase it.Now that I desire to be able to do Mold, Radon, and certified in many arenas the tools are key to a quality service. Count me in InterNACHI!
Mold inspections that can cover an arena of issues that tenants can suffer adverse affects from, and even though we are not health care professionals we are,“PEOPLE WHO CARE ABOUT PEOPLE PROFESSIONALS!” Part of the reason I got into this arena of professionalism was because of my regular influence in customer service and the satisfaction that it brought to do a service that significantly brought happiness and satisfaction to those I served. This is the next level of that service, and doing it and receiving financing for the service is only and added bonus.
My Essay.
This image is from under a kitchen sink, the concern comes from a property manager regarding a tenant complaint of mold under sink. This area was tested as dry with a moisture mete, no visible signs of leaks or prior leaks. Mold was not visibility noted.
My Essay.
This essay comes from the image gallery under the mold title dealing with bathroom ventilation. The picture shows shows proper and improper venting. Bathrooms are often a prime location for mold issues due to bathing, condensation and venting. It is better to have a fan light combination to always activate the fan to disperse moisture from the sink or shower.
The attached photo is in a kitchen cabinet located in the basement. More areas of growth were also discovered during the mold inspection as well. Upon entering the basement I immediately smelled the mold. I advised the client to get a professional to examine the mold and how to repair the problem.
Mold.
I’ve learned that mold can cause serious health problems. Getting rid of mold can be costly but needs to be done to prevent any health issues. If someone who has mold in the home is experiencing any health issues such as allergies they should seek a health care professional and get the mold in the home taken care of immediately.
