Starting electrical
Thank you for directing me to this thread. I will definitely use this thread if I have any questions as I take this course.
Getting started
Sparks may indicate a deficiency, right?
Getting started
Ready to start.
Ready to go
thanks for making this forum available
Gettimg started
Am beginning
Finish the equation: W = E x ____
R
Q
I
O
I didn’t notice any instruction regarding “W”
by the way ditto on the use of sub-panel in so much discussion but test using term distribution panel…continuity is less confusing
Starting course now.
In the training regarding Fuse panels, it says:
“The inspector should recommend the installation of S-type fuses and adapters to ensure that the circuits cannot be overloaded.”
My assumption is that I would right away recommend that they would upgrade their electrical system. So does this mean that it would still be acceptable to keep these systems? If so, in this case, would the insurance company likely charge the homeowner a higher premium?
Going
Just finished this section. A lot of good info.
Is there a checklist for electrical inspections? There was a good one in the chimney section so im wondering if there is one for this section. Thanx
Starting course now
ready to go
next section
Ready to take Performing Residential Inspections:)
Beginning the Electrical Inspection series.
