canderson5
(Cameron Anderson)
June 23, 2012, 9:03pm
…A deck with a ledger attached using carriage bolts inserted from the interior through the band joist and then through brick veneer?
mlarson
(Michael Larson, WI Lic. # 1672-106)
June 23, 2012, 9:08pm
2
How long the bolts and what size?
Pics?
mlarson
June 23, 2012, 9:11pm
3
jjonas
(Jeffrey Jonas)
June 23, 2012, 9:20pm
4
That graphic in itself is very misleading!!!
You need to read the very last sentence to get to the truth of the install!!!
Brick may look like a sturdy wall to attach a deck to but that is not the case. Brick is only a siding and should never support much of the load if any at all. You should never attach a deck to just the brick. You should always go through the house band joist or house foundation wall and carriage bolt the deck to the home. The brick isn’t attached to the home well enough to prevent a load shift and keep the deck from pulling way from the house all together. The deck may fall and take down the entire wall of bricks. When bolting on the ledger with any bolts you choose, do not tighten the bolt enough to crush the air space behind the brick wall. If the bolts are too tight, the wall can buckle, and the bricks above may fall down on top of you. If you are attaching the deck to a brick wall, most of the load should be resting on a beam set close to the home .
In other words, it should be a Free-standing deck!!!
Is it???
mlarson
June 23, 2012, 9:25pm
5
jjonas:
Is it???
I agree it could be more clear.
That is why i asked what size the carriage bolts where.
In most cases with would be better to build it as free standing next to brick veneer.
jjonas
(Jeffrey Jonas)
June 23, 2012, 9:39pm
6
Correct. The size of the bolt is irrelevent, as it should not be tightened to where it “closes” the air gap between the brick and the sheathing, therefore remaining “loose” (not torqued) which over time will continue to loosen, and contribute to deck failure.
kwood
(KEVIN WOOD, CMI)
June 23, 2012, 9:44pm
8
I have a picture of what happens to the brick after it is under pressure.
jjonas
(Jeffrey Jonas)
June 23, 2012, 10:02pm
9
Okay, post it. Why do you need someone to ask? Just do it. Be proactive!
gmathias1
(Greg Mathias, CCHI, CMI®)
June 23, 2012, 10:12pm
10
Oh god, I feel the nurse lurking here. Lets not talk bolt size or spacing for awhile.LOL.
I agree with you Jeff that it should be freestanding.
ccurrins
(Christopher Currins, CMI®)
June 23, 2012, 10:41pm
11
I see no issue. “carriage bolts inserted from the interior through the band joist”
canderson5
(Cameron Anderson)
June 23, 2012, 10:43pm
12
Yes, Kevin if you post that could I use it to show my client the results of this set up?
The bolts were undersized (3/8"), there was no flashing and the bolts didn’t alternate high/low. Multiple posts had shifted or dropped and even one of the beams was bowed away from the house where the two central posts had slid down the slight slope it is built on. So it had many many problems, but I was surprised at the differing opinions on bolting through the brick. I don’t like it and I recommended it be converted to a free standing deck. I was curious what opinions would be present here.
I’m not a big fan of carriage bolts either due to the reduced bearing the head will have as compared to a washer. Here’s some photos.
ccurrins
June 23, 2012, 10:50pm
13
canderson5:
You didn’t mention all of these problems in first post.
As for as going through the brick; as long as bolts are correct size/spaced and sealed with caulking at exterior, and of course band joist is sufficient, I see no issue.
kwood
(KEVIN WOOD, CMI)
June 23, 2012, 11:27pm
14
canderson5:
Here is what I put in the one on deck ledger calcs.
Don’t want to go back there again.
rcooke
(Roy D. Cooke, Sr)
June 23, 2012, 11:31pm
15
Thanks Guys good string I am sure we all learn from these type of posts.
Much appreciated .
kwood
(KEVIN WOOD, CMI)
June 23, 2012, 11:37pm
16
Since we all want to learn! What else is wrong?
jjonas
(Jeffrey Jonas)
June 24, 2012, 12:05am
19
ccurrins:
Chris… you did see that the brick was/is Veneer , correct?
http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Page 12.
ccurrins
June 24, 2012, 12:17am
20
In this case it’s not “attached” to the veneer, it’s attached to the band joist. Through the brick veneer.
