lol sure why not, you can anything you like Goldie dude… sup? How ya doing?
house had an INT system previously installed, kept leaking, was sold, buyer sees some more mold and efflorescence on some blocks inside basement…
here’s why it leaked and you can see some efflorescence on exterior of wall :10 -:30 mark
–a long EXTERIOR horizontal crack down low, vertical cracks, corner-cracks and the other openings under and around the side door in first part of video
So if Quality Dwy or Hydro or Mid Atlantic etc told homeowner (and they do!) to install an INT system and sump pump then THEY did NOT “waterproof” any of the existing defects, exterior cracks, and they will not stop-prevent further mold & efflorescence (as i said an IDIOT told previous owner an INT drainage system was ALL that was needed)
Quite a bit of mold on inside wall at corner here, this short video shows WHY, where, the water first got into the hollow block wall at—hnear the corner n i’ll sat it again ONLY exterior waterproofing done & backfilled correctly will SOLVE these problems sheesh unreal
So i’m supposed to just go away and shut up and not try to inform some homeowners and agree with the masses who mistakenly claim , all that is needed is an interior drainage system? Or raise and slope the grade? Or mudjack slabs? Or paint the walls with Drylok? Or just add a 600 mile long downspout extension and so on, pfft. People are getting LIED TO & ripped off, can’t they see this!
