Originally Posted By: dandersen
http://www.nachi.org/bbsystem/usrimages/D/DSC03633.JPG ]
My problem is that there are breaker knockouts on the front cover of the air handling unit but there is no place to install circuit breakers. Normally, a heat pump has separate circuits for the heat kit and the control/fan circuits. This unit has a 30 amp, 240 V breaker on the other side of the house which will unlikely trip in the event of motor failure.
[ Image: http://www.nachi.org/bbsystem/usrimages/D/DSC03636.JPG ]
Is this an equipment designed flaw?
There is a terminal block on the heater kit and all lower amperage circuits come off this terminal block and there is no way to seperate these circuits from seperate pulls from the disconnect box.
What are your interpetations of this wiring and equipment configuration?
