Originally Posted By: jonofrey This post was automatically imported from our archived forum.
The GFCI outlet protecting the multiple bathroom outlets failed under testing and could not be reset. The hydro-tub did not operate and no other means of protection could be found. Usually these tub motors are on their own circuit so it’s a no-brainer. I don’t think the hydro-tub should be on the bath outlet circuit. Is that right?
Quote:
210.11(C)(3) Bathroom Branch Circuits. In addition to the number of branch circuits required by other parts of this section, at least one 20 ampere branch circuit shall be provided to supply the bathroom receptacle outlet(s). Such circuit shall have no other outlets.
Receptacle outlets are required to be separate from fixture outlets (lights & fans). The hydro-massage tub is required to be GFCI protected, but not necessarily on its own circuit as far as I can tell.
-- Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: bbadger This post was automatically imported from our archived forum.
Quote:
210.11(C)(3)Exception: Where the 20-ampere circuit supplies a single bathroom, outlets for other equipment within the same bathroom shall be permitted to be supplied in accordance with 210.23(A).
So it is possible to power the tub from the same 20 amp circuit as the sink receptacle.
Originally Posted By: Greg Fretwell This post was automatically imported from our archived forum.
210.23(A)(2) can also apply
Utilization Equipment Fastened in Place. The total rating of utilization equipment fastened in place, other than luminaires (lighting fixtures), shall not exceed 50 percent of the branch-circuit ampere rating where lighting units, cord-and-plug-connected utilization equipment not fastened in place, or both, are also supplied.
