system
(system)
April 30, 2004, 12:00am
Originally Posted By: sgilligan This post was automatically imported from our archived forum.
Is this faulty because of the lack of angle? See anything else?
system
(system)
April 29, 2004, 12:00am
2
Originally Posted By: tallen This post was automatically imported from our archived forum.
1. The dishwasher drain line needs to have an air gap fitting installed…
2. It is hard to tell with the angle of the pic but the pipe must slope to drain.
That hot water line should be replaced with a braided stainless steel line
-- I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
system
(system)
3
Originally Posted By: jpeck This post was automatically imported from our archived forum.
Dishwasher drain line could have had a high loop installed installed instead of an air gap (but it didn’t).
– Jerry Peck
South Florida
system
(system)
4
oops forgot to mention that one
Thanks Jerry
system
(system)
5
Originally Posted By: Ryan Jackson This post was automatically imported from our archived forum.
I can’t quite tell, but it looks like the drainage fitting to connect the two sinks together is a Tee and should be a SanTee, unless it has an internal baffle.
– Ryan Jackson, Salt Lake City
system
(system)
6
Originally Posted By: hgordon This post was automatically imported from our archived forum.
Am I looking at this right? Is the water to the Dishwasher tapped in below the the shut-off? There’s a false sense of security!
Ditto the comments from Jerry and Todd by the way!
-- Harvey Gordon
SE Florida NACHI Chapter - President
hgordon@fl.nachi.org
system
(system)
7
Originally Posted By: rmagee This post was automatically imported from our archived forum.
Looks like there is a duplex receptacle installed behind the plumbing as well. Is it GFCI protected?
– Rick Magee
Building Check Ltd.
Fredericton, N.B. Canada
1-506-454-3332
bcheck@nbnet.nb.ca
“check with a professional”
system
(system)
8
No GFCI Rick. That is one of the reasons I posted, but apparently it does not need one.
system
(system)
9
Correct.
Kitchen - GFCI protection is only required for receptacles which serve the countertop spaces.
-- Jerry Peck
South Florida
system
(system)
May 1, 2004, 12:00am
10
Originally Posted By: dedwards This post was automatically imported from our archived forum.
moving the dishwasher “y” fitting to the other sink bowl to facilitate the high loop mentioned earlier and eliminate all the 90 degree turns currently shown. This would help to also eliminate possible backing up in the sink from the heavy flow during discharge. I see it all the time and that is usually the culprit. Switching to the other bowl allows almost a straight shot downward to the trap.
system
(system)
11
Originally Posted By: Bob Badger This post was automatically imported from our archived forum.
dedwards wrote:
This may be picking the fly crap out of the pepper
I never heard that before.
What's up with Air gaps, growing up we never had an air gap than the next house we did have the air gap. now I never see them.
Was it code for a while than change to against code?
Thanks, sorry to go OT.
Bob
-- Bob (AKA iwire)
ECN Discussion Forums
Mike Holt Code Forum
