I have hundreds if not thousands of thermal images that I’d be glad to help out with but I’m kinda at a loss as to exactly what to send you.
Are you doing separate brochures for Equine Thermal Imaging, Moisture Detection, Commercial, Thermal Roof Inspections, Energy Audits, Mechanical, etc… and if so which areas are you most interested in?
or
Are you trying to make a couple brochures that contain images from all different uses of IR? I can send images grouped as electrical, insulation, roofing, moisture, etc… or just send you a bunch of random images of everything?
Each area of inspection really needs it’s own brochure because there’s so much info to do with each area(this is just my opinion).
Are you trying to keep the brochures mainly focused on thermal imaging used during Home Inspections or all types of thermal inspections?
Last question, are you looking for full thermal images without any digital picture areas surrounding them or image’s within pictures(PIP)/Thermal Fusion type stuff?
Look at the different types of styles that I’ve posted, let me know what works best for you and I’ll start sending them your way.
You can also look through any of my websites or videos (http://www.youtube.com/user/UtahInfrared?feature=mhum) and use any of those images. If there’s any concerns that any images don’t belong to me, let me know which ones are in question and I’ll send you the originals along with the addresses of where and when the images were taken(other than 2 images that belong to FLIR)
Best of luck with this! I figure by helping you I’m also helping myself because I need some new brochures and art and design is definitely my weakness:mrgreen:
