Staple nailing asphalt roofs are not allowed in many jurisdictions and also not covered by many warranties. This is because the proper way to staple the shingle is to have the staple flush driven and also parallel to the front edge. It is very common for installers to twist their body or wrist and staple incorrectly.
This roof has a standing seam metal roof. There are two skylights installed into the roof. The flashing details of the skylights appear to have been correct. Even though the flashing looks to be correct, skylights are a notorious area for water intrusion and should be monitored.
The roof had a a few lichen present on the back left area. While this is mostly a cosmetic issues these organisms are difficult to remove without damaging the roof. It appears an attempt was made by someone to remove this lichen and in-turn damaged the shingle. There was only one shingle with exposed asphalt and the shingle appeared healthy. Generally this minor exposure will not cause any issues but the area should be monitored.
I read the article on “Mastering Roof Inspections: Asphalt Composition Shingles, Part 42” This section provided more information regarding algae on asphalt roofs. The article explained how rain runoff flowing across galvanized steel flashing can kill allege. This happens because galvanized metals are Zink heavy, the zink leaches into the water running across it and kills the algae.
photo curtsey of inch roof.net
Have found multiple shingles with bonding strip loose or not “tacky” and debris on bonding strip. asphalt roof coverings show signs of granual erosion. My recommendation is to have a roofing contractor do a more through evaluation.
no matter what climate you live in the roof coverings of a structure play an integral part of your structure, While its only one portion of the roof system its one of the most important components and should never be overlooked and inspected throughly.
This roof is covered with 3-tab asphalt shingles. At the time of the inspection, no signs of defect were observed in the shingles themselves. However, the uphill side of the chimney does not have a cricket (diverter) installed. When the side of a chimney that is parallel with the roof’s peak, has a width of 30" or greater, it is required to have a cricket, to divert water around the chimney. There are also signs (uneven shingle colors) that the shingles on the uphill side of the chimney may have been repaired/replaced at some point. I recommend further inspection and repair by a qualified roofing contractor.
Deciding whether or not to walk on a roof is at the discretion of the individual inspector. It is not required by the NACHI standards of practice to do so. Each inspector will have their own risk tolerance/comfort level. There are a number of factors that will contribute to the decision of whether or not o walk a roof: roof pitch, roof covering, moisture on the roof, number of stories of the home.
3 tab asphalt shingle roof. All shingles appear to be in good condition with no buckling, cracking, or tearing. All singles are lying flat and the bond of the sealing strip is strong. There is some galvanic staining visible below the roof vent which may cause future issues.
In the article “Ice Dams” we learn exactly how snow melt from a warm upper roof section flows down to a cold roof edge and then freezes causing the build up of the dam. As inspectors we should take note of this and then see if we can figure out where there may be a heat loss issue from the interior of the structure into the attic space, as this may be the cause for the roof temperature difference.
When doing an inspection of the roof we must be retailers with respect to the correct installation of the tiles, we observe a superposition in an edge near a corner that has two angles of which we must report to the owner about a possible future damage, by natural elements or external that can accelerate the deterioration of the tile and its surroundings diminishing its useful life and therefore the functional part as structural.
the directionality of the hail is spoken of the way the route will be, the direction and speed of the hail when they fall from the sky towards the earth and therefore in their trajectory fall on houses, cars and other objects that are in their travel or trajectory of fall
Roof inspection
Roof type: Gable
Roof covering type: Shingles
Comments: Some branches where found to close to roof components (Eaves/soffits/shingles), it could create future problems like damage to shingles or another roof component, pets/moisture intrusion. Its recommended to leave a separation between house components and tree branches
Wind damage:
Tornados category:
Category 1 = winds 74 to 95 miles per hour;
Category 2 = winds 96 to 110 miles per hour;
Category 3 = winds 111 to 130 miles per hour;
Category 4 = winds 131 to 155 miles per hour; and
Category 5 = winds greater than 155 miles per hour.
This fact is important to know at the moment of inspecting roof components, and what kind of roof coverings are use in some high wind zones of the country.
Inspection of a roof with 3 tab asphalt shingles. The underlayment was installed under the drip edge allowing water to get behind the drip edge and seep water into the wall above the master bedroom window. The roof also has a 3:12 slope.
Inspecting roofs with asphalt shingles. Although many roofs with asphalt shingles appear the same, they can vary largely with performance due to different manufacturers. The difference in the amount of adhesive on the adhesive strip alone can be the difference between shingles being torn off and shingles remaining in place.
While inspecting the asphalt tile roof at the time of inspection the owner commented that the roof was a couple years old. It appeared to be in dood condition except on west side by ghe ridge. There us a tile over a peace of motar. This needs to be removed and resealed.
I read the article on hail damage. I didnt realize that hail damage accounts for more damage dollar wise campared to fire and water damage. I also didnt realize that there are not a standard for hail damage through out the industry.
The above photo is of an asphalt shingle roof that is in very poor condition and should be noted in the inspectors report to the customer. The photo shows how bad that the deterioration of the roof tiles has become.
The topic of roofing underlayment is very important to making sure that the roof tiles are installed properly. There are three different types of roofing underlayment that are used on homes. the three different types are: asphalt saturated felt, rubberized asphalt, and non bitumen synthetic.
