Inspection of an asphalt shingle roof should include a visual inspection of flashing eaves and overhangs as well as many other systems. This gutter system is clogged and not functioning properly causing excessive moisture at the roof edge. It was confirmed that some of the seal stripped on the bottom layer were loose.
This essay is on hail damage on roofs and that homeowners in the past have attempted to fake hail damage to receive money for a new roof surface. Apparently the average attemp is fairly obvious as hail damage is very specific in its randomness.
Nothing too fancy here. Totally new construction in the New York City area. One thing that I did find interesting is that they did not install any ice and snow shield (peel and stick) around the edges or in the valleys. I am from Florida and that is where my license will be, but I assumed it was a requirement in the Northeast. We have it installed on many new roofs in Florida, for extra strength and to protect from leaks, in the event of a mild tropical storm.
I decided to read the article about Modular vs Manufactured housing. I am looking to buy property in Alabama and have been considering what to do about housing. I like the idea of modular housing. I believe the conditions can be better controlled with more precise construction practices and with pre planning, all the unseen could be taking out of the equation.The styles seem to have really come along, also.
Roofing consists of architectural style shingles, also known as laminated or dimensional shingles they are made up of a heavy fiber glass mat base and ceramic mineral granules that are embedded in water resistant asphalt. . These are a thicker, longer lasting shingle with a dimensional appeal. The design life of an average Architectural shingle is 25-35 years. Architectural shingles are nearly twice as thick as three-tab shingles resulting in more durability and are less likely to curl.
One must take precaution and be careful when accessing a roof. Not all roofs are safe to access. One must take several factors into consideration when trying to safely navigate a roof. If a roof has wet icy conditions the roof may be viewed from the ground only. But you may want to document that at time of inspection NO leaks were identified. You may have to state in your report that there was limited visibility due to snow cover as well. Remember though one may also ladder the eaves in different locations to get a better view of different areas of the roof without putting yourself in a unsafe situation. Safety always comes first.
As for roofing shingles essay we will talk about when would be best to install shingles . When you install shingles in cold climate the adhesive strip will never bond , which may cause shingles to be blown off in high winds
This is a picture of a roof system take in a location with high wind, one of the shingles is missing du to a bad bounding of the adhesive strap, we can see that the corner of the shingle are lifting, this situation is related to mom efficiency of the attic ventilation
When installing roofing shingle in a high wind location, its realy importent to chose the right shingle type and follow the manufacturer specification, the number of fastener is realy important, most of the supplier would ask to use roof cement to bound the shingles together
The roof covering material installed is a 3-tab asphalt shingles, although it is covered in snow it looks to be in good condition and cant determine any offset patterns and valley flashing.
Unable to walk the roof due to the cold season, I cant determine the type of fasterners used, deck sheathing and underlayment if present.
No signs of ice dams. Drip edges are present.
Wood stove chimney is used and looks to be in good condition, no missing cap. Plumbing and stacks are present
Overall the condition of the roof is okay and will be further evaluated during the warmer seasons.
OSB plywood is also referrable to chip plywood and can be used on roof sheathing as long as it passes by 3/8 or 7/16 of an inch its durable and light weight and can be used in many ways as needed.
The article kick out flashing also know as diverted flashing protects the building exterior walls/envelope from water intrusion, which can sheep through the cladding if not present or properly installed. Since the buildings are now more well insulated, it is crucial that Kickout flashing be installed in every home to prevent absorption into the buildings envelope. With could lead to serious damage and drop the life expectancies of any building.
This is a Laminate thirty year Asphalt shingle. It appears to be at least 5 years old. Because of the surrounding tree cover and frequent rainfall in this season algae is very clearly visible. The Material appears to be at least 5 years old. It has been exposed to moisture as evidenced by discoloration, but no significant deficiencies in the covering could be seen from the ground
I Read “Mastering Roof Inspections: Roof Styles” by Nick Gromicko and Kenton Shepard. There are many Varieties of roof including, Gambrel, Mansard, Flat, Gable, Hip, Butterfly, Bonnet and Shed styles. There are several features which include clerestory windows, Cupola, and conical roofs. Each of these styles produce differing concerns when it comes to roof covering materials, and the integrity of installation, fasteners, etc.
As you can see here on the roof, there are no gutters. Due to that, run of from the roof sheds directly infront of a door. the real issue here is that there is no proper kickout flashing where there should be, so water is not being kicked away from the door.
Often when people are speaking about both composite and asphalt shingles, they use the two interchangeably. Shingles are manufactured as a composite of minerals, asphalt, and mat. The reason they use the word composites composite as opposed to just calling it a shingle, is because before asphalt shingles became popular or preferred, there was a lot of roof coverings made of a single substance like wood.
Asphalt Shingles: It has been observed that there is a green stain on the fascia coming off the roof. It can be seen from the ground that there is plant growth on the roof. This is a sign of debris on the roof that has restricted proper water drainage for an extended period of time. This condition can lead to leaks in the roof and pre-mature aging and damage to the shingle(s). It is recommended that the area of the roof be cleaned and the affected shingles be inspected by a licensed roofing contractor.
Asphalt Composition Shingles Pt.1: Asphalt and composition are terms refering to the same type of product. These are shingles made of three basic layers; asphalt, woven fiberglass (the mat), and minerals. They are much more durable than organic shingles which have a cellulose based mat. Even though the woven mat is only 2% of the shingles weight, it provides a great deal of the shingles strength in order to resist tearing or splitting.
Attached is a photo the roof of a single family dwelling. After performing a visual inspection of the roof from the ground, and then also having a closer inspection of the roofs in the racks, eves & the granular condition of the roofs shingles. The conclusion was that, this particular roof is in very good condition.
A shingle gauge is a tool to measure the thickness of a roof’s asphalt composition shingles. The measurement is used to estimate the level of warranty for shingles. Being aware of the shingle’s warranty level can help in the purchase of comparable replacement shingles, as well as determining whether the shingles are wearing according to their advertised service life, and not substantially sooner.
